Aller au contenu principal
Dell Inspiron B130 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron B130 Hard Drive Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron B130 Hard Drive Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron B130 Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Hard Drive Replacement: étape 2, image 1 de 3 Dell Inspiron B130 Hard Drive Replacement: étape 2, image 2 de 3 Dell Inspiron B130 Hard Drive Replacement: étape 2, image 3 de 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Hard Drive Replacement: étape 3, image 1 de 3 Dell Inspiron B130 Hard Drive Replacement: étape 3, image 2 de 3 Dell Inspiron B130 Hard Drive Replacement: étape 3, image 3 de 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • This particular computer is missing its hard drive.
    • Remove the two screws.
    • Remove the plastic cover by lifting from the groove as indicated.
    • Remove the hard drive from the computer by lifting up and out.
Patrick McNeil
Membre depuis le 10/19/16
937 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 668
