Aller au contenu principal
Dell Inspiron B130 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron B130 Motherboard Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron B130 Motherboard Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron B130 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Motherboard Replacement: étape 2, image 1 de 3 Dell Inspiron B130 Motherboard Replacement: étape 2, image 2 de 3 Dell Inspiron B130 Motherboard Replacement: étape 2, image 3 de 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Motherboard Replacement: étape 3, image 1 de 3 Dell Inspiron B130 Motherboard Replacement: étape 3, image 2 de 3 Dell Inspiron B130 Motherboard Replacement: étape 3, image 3 de 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Motherboard Replacement, Disk Drive: étape 4, image 1 de 3 Dell Inspiron B130 Motherboard Replacement, Disk Drive: étape 4, image 2 de 3 Dell Inspiron B130 Motherboard Replacement, Disk Drive: étape 4, image 3 de 3
    • Remove the 8mm screw
    • Use the plastic opening tool to push out the disk drive.
    • Pull the disk drive out with the opposite hand.
  5. Dell Inspiron B130 Motherboard Replacement: étape 5, image 1 de 1
    • You can now remove the disk drive.
  6. Dell Inspiron B130 Motherboard Replacement, Hard Drive: étape 6, image 1 de 3 Dell Inspiron B130 Motherboard Replacement, Hard Drive: étape 6, image 2 de 3 Dell Inspiron B130 Motherboard Replacement, Hard Drive: étape 6, image 3 de 3
    • This particular computer is missing its hard drive.
    • Remove the two screws.
    • Remove the plastic cover by lifting from the groove as indicated.
    • Remove the hard drive from the computer by lifting up and out.
  7. Dell Inspiron B130 Motherboard Replacement, Keyboard: étape 7, image 1 de 1
    • Put down the computer and open up the screen.
    • There is a long piece of plastic underneath the screen that you will have to remove.
  8. Dell Inspiron B130 Motherboard Replacement: étape 8, image 1 de 3 Dell Inspiron B130 Motherboard Replacement: étape 8, image 2 de 3 Dell Inspiron B130 Motherboard Replacement: étape 8, image 3 de 3
    • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
    • Insert the plastic opening tool into the little slot.
    • Lift up gently and remove the plastic cover.
  9. Dell Inspiron B130 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the two 4mm screws at the top of the keyboard.
    • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
  10. Dell Inspiron B130 Motherboard Replacement: étape 10, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 10, image 2 de 2
    • Lift keyboard up slightly and you will see the keyboard connection.
    • This black tab has to be lifted up to remove the keyboard.
    • Put your finger underneath the tab and pull back gently as indicated.
    • You can now remove the keyboard.
  11. Dell Inspiron B130 Motherboard Replacement, Screen: étape 11, image 1 de 3 Dell Inspiron B130 Motherboard Replacement, Screen: étape 11, image 2 de 3 Dell Inspiron B130 Motherboard Replacement, Screen: étape 11, image 3 de 3
    • After opening the panel, you will see two cable connections attached to the screen.
    • Identify the one with blue tape this is the display connector that needs to be removed.
  12. Dell Inspiron B130 Motherboard Replacement: étape 12, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 12, image 2 de 2
    • Locate the second connector next to the one removed in the previous step, This connector does not have blue tape but still needs to be detached. To remove it safely hold both sides of the connector firmly. Pull it straight apart avoid twisting or pulling at an angle to prevent damage.
  13. Dell Inspiron B130 Motherboard Replacement: étape 13, image 1 de 1
    • Locate the two 6mm screws positioned directly beneath the screen. Use a Phillips #1 screwdriver to remove both screws. Keep the screws in a safe place, as they will be needed for reassembly.
  14. Dell Inspiron B130 Motherboard Replacement: étape 14, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 14, image 2 de 2
    • Close the computer and flip it over so that the back is facing up.
    • Remove the two 6mm screws that are behind each of the screens pivot points. Use a Phillips #1 screwdriver to remove these screws.
    • Open up the screen and now it can be lifted up and off of the computer.
  15. Dell Inspiron B130 Motherboard Replacement, CPU: étape 15, image 1 de 2 Dell Inspiron B130 Motherboard Replacement, CPU: étape 15, image 2 de 2
    • Remove the 6 mm screw.
    • Lift the plastic cover off.
  16. Dell Inspiron B130 Motherboard Replacement: étape 16, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 16, image 2 de 2
    • Loosen the 4 screws.
    • These screws stay connected to the heat sink.
    • Remove the heat sink from the computer.
  17. Dell Inspiron B130 Motherboard Replacement: étape 17, image 1 de 1
    • Use a flat head screwdriver to turn the screw one quarter turn into the unlock position.
    • Remove the CPU.
  18. Dell Inspiron B130 Motherboard Replacement, RAM and Wireless: étape 18, image 1 de 2 Dell Inspiron B130 Motherboard Replacement, RAM and Wireless: étape 18, image 2 de 2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  19. Dell Inspiron B130 Motherboard Replacement: étape 19, image 1 de 3 Dell Inspiron B130 Motherboard Replacement: étape 19, image 2 de 3 Dell Inspiron B130 Motherboard Replacement: étape 19, image 3 de 3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  20. Dell Inspiron B130 Motherboard Replacement: étape 20, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 20, image 2 de 2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  21. Dell Inspiron B130 Motherboard Replacement: étape 21, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 21, image 2 de 2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
  22. Dell Inspiron B130 Motherboard Replacement, Motherboard: étape 22, image 1 de 2 Dell Inspiron B130 Motherboard Replacement, Motherboard: étape 22, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the twelve 8mm screws from the bottom of the laptop. Keep the screws organized to avoid losing them.
    • The picture shows everything still installed in the computer. At this point, the CPU, RAM, battery, hard drive and wireless chip should all be removed.
  23. Dell Inspiron B130 Motherboard Replacement: étape 23, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 23, image 2 de 2
    • Turn the laptop over so that the keyboard side is facing up, then locate and remove the two 4mm screws positioned just below where the screen would be using a Phillips #0 screwdriver.
    • Remove the five remaining 6mm screws. Be sure to keep track of these screws, as they will be needed for reassembly.
  24. Dell Inspiron B130 Motherboard Replacement: étape 24, image 1 de 2 Dell Inspiron B130 Motherboard Replacement: étape 24, image 2 de 2
    Outil utilisé dans cette étape :
    • Disconnect the two connections carefully.
    • Do not pull by the wires! This can damage the connection. Use tweezers to grab by the white plastic piece and push outward.
  25. Dell Inspiron B130 Motherboard Replacement: étape 25, image 1 de 3 Dell Inspiron B130 Motherboard Replacement: étape 25, image 2 de 3 Dell Inspiron B130 Motherboard Replacement: étape 25, image 3 de 3
    • Disconnect this connection before proceeding.
    • Use tweezers to grab the small black connector and pull it straight back carefully. Avoid pulling on the wire directly, as this may cause damage to the connection.
    • You can now disconnect this wire.
  26. Dell Inspiron B130 Motherboard Replacement: étape 26, image 1 de 3 Dell Inspiron B130 Motherboard Replacement: étape 26, image 2 de 3 Dell Inspiron B130 Motherboard Replacement: étape 26, image 3 de 3
    • Lift and remove the entire cover/frame from the top of the motherboard. Gently pull up to detach it without using excessive force
    • Remove the motherboard by pulling it upward and sliding it to the right. Be careful not to damage any remaining connectors or components. If the motherboard feels stuck, double-check that all screws and cables have been disconnected.
Patrick McNeil
Membre depuis le 10/19/16
937 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 364
