Aller au contenu principal
Dell Inspiron B130 RAM and Wireless Replacement
Ce dont vous avez besoin
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: étape 1, image 3 de 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: étape 2, image 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement: étape 2, image 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement: étape 2, image 3 de 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: étape 3, image 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement: étape 3, image 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement: étape 3, image 3 de 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: étape 4, image 1 de 2 Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: étape 4, image 2 de 2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: étape 5, image 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement: étape 5, image 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement: étape 5, image 3 de 3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: étape 6, image 1 de 2 Dell Inspiron B130 RAM and Wireless Replacement: étape 6, image 2 de 2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: étape 7, image 1 de 2 Dell Inspiron B130 RAM and Wireless Replacement: étape 7, image 2 de 2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
Patrick McNeil
Membre depuis le 10/19/16
937 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 299
