Aller au contenu principal
Dell Inspiron Duo Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron Duo Battery Replacement, Front Cover: étape 1, image 1 de 2 Dell Inspiron Duo Battery Replacement, Front Cover: étape 1, image 2 de 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
  2. Dell Inspiron Duo Battery Replacement: étape 2, image 1 de 2 Dell Inspiron Duo Battery Replacement: étape 2, image 2 de 2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
  3. Dell Inspiron Duo Battery Replacement: étape 3, image 1 de 2 Dell Inspiron Duo Battery Replacement: étape 3, image 2 de 2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
  4. Dell Inspiron Duo Battery Replacement, Battery: étape 4, image 1 de 2 Dell Inspiron Duo Battery Replacement, Battery: étape 4, image 2 de 2
    • Remove the cover, and locate the battery. The battery can be found in the lower portion of the device. It will have a blue Li-ion Recycling symbol on the right half, and "Dell Inc. Dell Battery Module" on the left side.
    • Remove the two screws from the bottom center of the battery, the two screws from the top outside corners, and the single screw in the top-center.
  5. Dell Inspiron Duo Battery Replacement: étape 5, image 1 de 2 Dell Inspiron Duo Battery Replacement: étape 5, image 2 de 2
    • Lastly, remove the white power connector that attaches the battery to the motherboard ( to make this easier to see, the power connector is outlined in red in the photograph). Now remove the battery from the device and place to the side.
8 autres ont terminé cette réparation.
Steven Luther
Membre depuis le 06/23/15
778 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team 1-1, Liner SU 2015 Membre de l'équipe UW Tacoma, Team 1-1, Liner SU 2015
UWT-LINER-SU15S1G1
3 membres
4 tutoriels rédigés
Un commentaire
i want the battery my email is engkaim95@gmail,com
KAIMUKILWA J TIBAZARWA - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 43
Total : 9,044
