Aller au contenu principal
Dell Inspiron E1405 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron E1405 RAM Replacement, Battery: étape 1, image 1 de 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 RAM Replacement: étape 2, image 1 de 3 Dell Inspiron E1405 RAM Replacement: étape 2, image 2 de 3 Dell Inspiron E1405 RAM Replacement: étape 2, image 3 de 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 RAM Replacement, RAM: étape 3, image 1 de 3 Dell Inspiron E1405 RAM Replacement, RAM: étape 3, image 2 de 3 Dell Inspiron E1405 RAM Replacement, RAM: étape 3, image 3 de 3
    • Locate the RAM access door.
    • Remove the two 5.5mm screws securing the RAM access door with a #00 Phillips screwdriver.
  4. Dell Inspiron E1405 RAM Replacement: étape 4, image 1 de 1
    • Using your fingers, open and remove the access door from the laptop, exposing the RAM underneath.
  5. Dell Inspiron E1405 RAM Replacement: étape 5, image 1 de 3 Dell Inspiron E1405 RAM Replacement: étape 5, image 2 de 3 Dell Inspiron E1405 RAM Replacement: étape 5, image 3 de 3
    • To access the RAM, push out the latches outward on the left and right of the RAM.
    • To remove the memory card, pull it out of the tray with the latches still stretched out.
Sarah Neal Secrest
Membre depuis le 03/20/17
597 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S8-G3, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S8-G3, Bennett Spring 2017
TTU-BENNETT-S17S8G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 569
