Aller au contenu principal
Dell Inspiron E1705 Battery Replacement
  1. Dell Inspiron E1705 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron E1705 Battery Replacement: étape 2, image 2 de 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
To replace your battery, follow these instructions in reverse order.
5 autres ont terminé cette réparation.
Malik Shahbal
Membre depuis le 10/05/10
471 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 22-5, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 membres
11 tutoriels rédigés
Un commentaire
I think it would be complete if we knew where to buy it as well.
Nobody would read up on changing a battery if he didn’t need one, so you might as well tell him where to get it.
I think that makes sense. However thank you for your effort.
kjanmunkedal - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 15
Total : 4,330
