Ce dont vous avez besoin
Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
Remove the 12 Phillips #1 screws from the edges of the lower case.
You may also need to remove the central screw next to the lock icon.
Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them.
Carefully unplug the connections shown.
Also, the wireless cables on the right side may prevent moving the upper case out of the way.
Once the screws have been removed and the connections unplugged, use the plastic opening tool to gently separate the panel from the lower case.
Remove both fans from the computer. This will make it easier to remove the motherboard.
Remove the screws in the photos to remove the fans.
Gently remove the motherboard from the laptop by simultaneously lifting and pulling away from the sides.
Once the motherboard is free, flip it over, towards the screen of the laptop and gently remove the black and white wire from the wireless card.
Once the wires are disconnected, pull them through the hole and completely remove the motherboard from the computer.
5 autres ont terminé cette réparation.
