Aller au contenu principal
Dell Inspiron E1705 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: étape 2, image 1 de 2 Dell Inspiron E1705 Optical Drive Replacement: étape 2, image 2 de 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: étape 3, image 1 de 1
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: étape 4, image 1 de 2 Dell Inspiron E1705 Optical Drive Replacement: étape 4, image 2 de 2
    • Use the screwdriver to gently push the optical drive out
3 autres ont terminé cette réparation.
Evan Fairchild
Membre depuis le 10/05/10
613 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 22-5, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 11
Total : 3,953
