Aller au contenu principal
Dell Inspiron E1705 Upper Case and Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: étape 1, image 1 de 1
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: étape 2, image 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: étape 2, image 2 de 2
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: étape 3, image 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: étape 3, image 2 de 2
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: étape 4, image 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: étape 4, image 2 de 2
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: étape 5, image 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: étape 5, image 2 de 2
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
9 autres ont terminé cette réparation.
Evan Fairchild
Membre depuis le 10/05/10
613 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 22-5, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 19
Total : 7,015
