Aller au contenu principal
Dell Inspiron M5010 Camera Replacement
Ce dont vous avez besoin
  1. Dell Inspiron M5010 Camera Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron M5010 Camera Replacement, Battery: étape 1, image 2 de 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Camera Replacement, Remove keyboard retaining screw: étape 2, image 1 de 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Camera Replacement: étape 3, image 1 de 3 Dell Inspiron M5010 Camera Replacement: étape 3, image 2 de 3 Dell Inspiron M5010 Camera Replacement: étape 3, image 3 de 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Camera Replacement: étape 4, image 1 de 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Camera Replacement: étape 5, image 1 de 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 Camera Replacement, Palm Rest: étape 6, image 1 de 1
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 Camera Replacement: étape 7, image 1 de 2 Dell Inspiron M5010 Camera Replacement: étape 7, image 2 de 2
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 Camera Replacement: étape 8, image 1 de 1
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 Camera Replacement: étape 9, image 1 de 3 Dell Inspiron M5010 Camera Replacement: étape 9, image 2 de 3 Dell Inspiron M5010 Camera Replacement: étape 9, image 3 de 3
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  10. Dell Inspiron M5010 Camera Replacement, LCD Screen: étape 10, image 1 de 1
    • Flip the laptop over to its backside.
    • Using the Phillips #000 Screwdriver remove the six indicated 6.0mm Phillips #000 screws.
  11. Dell Inspiron M5010 Camera Replacement: étape 11, image 1 de 1
    • Flip the laptop over to its front side and open the laptop.
    • Remove the four 6.0mm Phillips #000 screws holding the screen to the base of the laptop using a Phillips #000 Screwdriver.
  12. Dell Inspiron M5010 Camera Replacement: étape 12, image 1 de 2 Dell Inspiron M5010 Camera Replacement: étape 12, image 2 de 2
    • Pull up both the black and white chords to completely detach the screen.
  13. Dell Inspiron M5010 Camera Replacement: étape 13, image 1 de 2 Dell Inspiron M5010 Camera Replacement: étape 13, image 2 de 2
    • Lift the screen from the base of the laptop.
  14. Dell Inspiron M5010 Camera Replacement: étape 14, image 1 de 2 Dell Inspiron M5010 Camera Replacement: étape 14, image 2 de 2
    • Use a spudger to separate and remove the plastic frame on the front of the screen.
  15. Dell Inspiron M5010 Camera Replacement: étape 15, image 1 de 2 Dell Inspiron M5010 Camera Replacement: étape 15, image 2 de 2
    • Use a Phillips #000 Screwdriver to remove the 8 6.0mm Phillips #000 screws marked in the image.
  16. Dell Inspiron M5010 Camera Replacement: étape 16, image 1 de 1
    • Lift LCD screen from the plastic frame.
  17. Dell Inspiron M5010 Camera Replacement: étape 17, image 1 de 3 Dell Inspiron M5010 Camera Replacement: étape 17, image 2 de 3 Dell Inspiron M5010 Camera Replacement: étape 17, image 3 de 3
    • Flip LCD screen over to view the backside.
    • Lift brown tab in the middle of the screen and pull to remove the entire piece.
  18. Dell Inspiron M5010 Camera Replacement: étape 18, image 1 de 2 Dell Inspiron M5010 Camera Replacement: étape 18, image 2 de 2
    • Use a Phillips #000 Screwdriver to remove the four screws indicated (two on each side).
    • Pull metal frames away from LCD screen.
    • The metal frame on each side is pulled away separately, so make sure to make note of which side each one came from.
  19. Dell Inspiron M5010 Camera Replacement, Camera: étape 19, image 1 de 2 Dell Inspiron M5010 Camera Replacement, Camera: étape 19, image 2 de 2
    • Using a Phillips #000 Screwdriver, remove the indicated 6.0 mm screw on the left side of the camera.
    • Pull the tab and release the ribbon on the right side of the camera.
    • Pull the camera away from the plastic frame.
April Poucher
Membre depuis le 10/13/14
1 164 Réputation
10 tutoriels rédigés
Équipe
Clemson, Team 1-5, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 10
Total : 231
