Aller au contenu principal
Dell Inspiron M5010 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over and remove the two screws.
  2. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Cables: étape 2, image 1 de 1
    • Disconnect the Mini-Card antenna cables from the Mini-Card.
  3. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Display Cable: étape 3, image 1 de 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  4. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron M5010 Display Assembly Replacement, Lifting the Display Assembly: étape 5, image 1 de 1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron M5010 Display Assembly Replacement, Placing the Display Assembly: étape 6, image 1 de 1
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron M5010 Display Assembly Replacement, Route the Display Cable: étape 7, image 1 de 1
    • Route the display cable into the routing guide and connect the cable to the connector on the system board.
  8. Dell Inspiron M5010 Display Assembly Replacement, Connecting the Mini-Card Antenna Cables: étape 8, image 1 de 1
    • Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
  9. Dell Inspiron M5010 Display Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Turn the computer over and replace the two screws at the bottom of the computer.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 227
