Aller au contenu principal
Dell Inspiron M5010 SD Card Slot Replacement
Ce dont vous avez besoin
  1. Dell Inspiron M5010 SD Card Slot Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron M5010 SD Card Slot Replacement, Battery: étape 1, image 2 de 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 SD Card Slot Replacement, Remove keyboard retaining screw: étape 2, image 1 de 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 SD Card Slot Replacement: étape 3, image 1 de 3 Dell Inspiron M5010 SD Card Slot Replacement: étape 3, image 2 de 3 Dell Inspiron M5010 SD Card Slot Replacement: étape 3, image 3 de 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 SD Card Slot Replacement: étape 4, image 1 de 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 SD Card Slot Replacement: étape 5, image 1 de 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 SD Card Slot Replacement, Palm Rest: étape 6, image 1 de 1
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 SD Card Slot Replacement: étape 7, image 1 de 2 Dell Inspiron M5010 SD Card Slot Replacement: étape 7, image 2 de 2
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 SD Card Slot Replacement: étape 8, image 1 de 1
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 SD Card Slot Replacement: étape 9, image 1 de 3 Dell Inspiron M5010 SD Card Slot Replacement: étape 9, image 2 de 3 Dell Inspiron M5010 SD Card Slot Replacement: étape 9, image 3 de 3
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  10. Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: étape 10, image 1 de 3 Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: étape 10, image 2 de 3 Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: étape 10, image 3 de 3
    • Unplug the SD Card Slot cable.
    • Gently lift the SD Card Slot from the computer.
April Poucher
Membre depuis le 10/13/14
1 164 Réputation
10 tutoriels rédigés
Équipe
Clemson, Team 1-5, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 451
