Aller au contenu principal
Dell Inspiron M5110 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron M5110 Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Optical Drive Replacement: étape 2, image 1 de 1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Optical Drive Replacement: étape 3, image 1 de 1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Optical Drive Replacement, Module Cover: étape 4, image 1 de 2 Dell Inspiron M5110 Optical Drive Replacement, Module Cover: étape 4, image 2 de 2
    • Remove the 5 mm Phillips # 0 screw in the middle of the device.
  5. Dell Inspiron M5110 Optical Drive Replacement: étape 5, image 1 de 1
    • Remove the module cover pressing in the release tabs and pulling the cover up and away from the base of the device.
  6. Dell Inspiron M5110 Optical Drive Replacement, Optical Drive: étape 6, image 1 de 2 Dell Inspiron M5110 Optical Drive Replacement, Optical Drive: étape 6, image 2 de 2
    • Insert a small screwdriver into the hole and slide the optical drive away from the center of the device. This will slide the optical assembly out from the side of the device.
  7. Dell Inspiron M5110 Optical Drive Replacement: étape 7, image 1 de 1
    • Slide the optical drive assembly the rest of the way out of the device.
Cody Flynn
Membre depuis le 10/18/16
331 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-3, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 8
Total : 234
