Aller au contenu principal
Dell Inspiron M511R Module Cover Replacement
Ce dont vous avez besoin
  1. Dell Inspiron M511R Module Cover Replacement, REMOVE BATTERY: étape 1, image 1 de 1
    • Insert wisdom here.
  2. Dell Inspiron M511R Module Cover Replacement, Removing the Module Cover: étape 2, image 1 de 1
    • Loosen the captive screw that secures the module cover to the base cover
    • Using your fingertips, release the tabs on the module cover from the slots on the computer base
    • Lift the module cover off the computer base
  3. Dell Inspiron M511R Module Cover Replacement, removing memory module: étape 3, image 1 de 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • Remove the memory module from the memory-module connector.
  4. Dell Inspiron M511R Module Cover Replacement, Replacing the Memory Module: étape 4, image 1 de 1
    • align the notch in the memory module with the tab in the memory-module connector.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Replace the module cover
    • Replace the battery
Jordon Dozier
Membre depuis le 02/10/21
1 663 Réputation
12 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 22
