Aller au contenu principal
Dell Inspiron M531R-5535 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron M531R-5535 Fan Replacement, Fan: étape 1, image 1 de 3 Dell Inspiron M531R-5535 Fan Replacement, Fan: étape 1, image 2 de 3 Dell Inspiron M531R-5535 Fan Replacement, Fan: étape 1, image 3 de 3
    • Flip the laptop over and unlock the battery.
    • Lift up to remove the battery.
  2. Dell Inspiron M531R-5535 Fan Replacement: étape 2, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 2, image 2 de 2
    • Loosen the two Phillips #1 screws to remove the tray.
    • The screws stay in the tray.
  3. Dell Inspiron M531R-5535 Fan Replacement: étape 3, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 3, image 2 de 2
    • Unscrew the 3.6mm Phillips #1 screw.
    • Slide the CD Drive out.
  4. Dell Inspiron M531R-5535 Fan Replacement: étape 4, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 4, image 2 de 2
    • Unscrew nine 5.7mm Phillips #1 screws.
    • Unscrew three 5.6mm Phillips #1 screws
    • The three 5.6mm Phillips #1 screws are thinner.
    • Then flip the laptop and open it to see the keyboard.
  5. Dell Inspiron M531R-5535 Fan Replacement: étape 5, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 5, image 2 de 2
    • Use a nylon spudger or plastic opening tool to press into the highlighted keyboard latches.
  6. Dell Inspiron M531R-5535 Fan Replacement: étape 6, image 1 de 3 Dell Inspiron M531R-5535 Fan Replacement: étape 6, image 2 de 3 Dell Inspiron M531R-5535 Fan Replacement: étape 6, image 3 de 3
    • Lift up the keyboard.
    • Lift up on the black ZIF tab and pull the keyboard ribbon cable free.
  7. Dell Inspiron M531R-5535 Fan Replacement: étape 7, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 7, image 2 de 2
    • Unscrew the five 5.6mm Phillips #1 screws.
    • Unscrew the two 3.6mm Phillips #1 screws.
  8. Dell Inspiron M531R-5535 Fan Replacement: étape 8, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 8, image 2 de 2
    • Disconnect all highlighted cables.
  9. Dell Inspiron M531R-5535 Fan Replacement: étape 9, image 1 de 2 Dell Inspiron M531R-5535 Fan Replacement: étape 9, image 2 de 2
    • Using an opening tool, carefully pry open the case from the side.
  10. Dell Inspiron M531R-5535 Fan Replacement: étape 10, image 1 de 1
    • Unscrew the Phillips #1 screw.
    • Pull the white connector out to disconnect the cables from the motherboard.
    • Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
    • Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
  11. Dell Inspiron M531R-5535 Fan Replacement: étape 11, image 1 de 1
    • Flip the motherboard over.
    • Pull the white connector out to disconnect the fan.
    • Lift the fan to remove it from the motherboard.
2 autres ont terminé cette réparation.
Tony Chen
Membre depuis le 09/26/22
310 Réputation
2 tutoriels rédigés
Équipe
CSU Los Angeles, Team 6-5, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 6-5, Adachi Fall 2022
CSULA-ADACHI-F22S6G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 5
Total : 246
