Aller au contenu principal
Dell Inspiron Mini 10 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron Mini 10 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Hard Drive Replacement, Palm Rest: étape 3, image 1 de 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Hard Drive Replacement: étape 4, image 1 de 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Hard Drive Replacement, Keyboard: étape 5, image 1 de 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  6. Dell Inspiron Mini 10 Hard Drive Replacement: étape 6, image 1 de 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  7. Dell Inspiron Mini 10 Hard Drive Replacement: étape 7, image 1 de 2 Dell Inspiron Mini 10 Hard Drive Replacement: étape 7, image 2 de 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  8. Dell Inspiron Mini 10 Hard Drive Replacement: étape 8, image 1 de 2 Dell Inspiron Mini 10 Hard Drive Replacement: étape 8, image 2 de 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  9. Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: étape 9, image 1 de 2 Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: étape 9, image 2 de 2
    • Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
  10. Dell Inspiron Mini 10 Hard Drive Replacement: étape 10, image 1 de 2 Dell Inspiron Mini 10 Hard Drive Replacement: étape 10, image 2 de 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port until is comes free.
  11. Dell Inspiron Mini 10 Hard Drive Replacement: étape 11, image 1 de 1
    • Unscrew the four 3mm screws, two on each side of the drive, and slide the drive free from the cage.
3 autres ont terminé cette réparation.
Bariso Shuba
Membre depuis le 10/26/16
270 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 35
Total : 7,554
