Remove the battery
  • Remove the battery
Ajouter un commentaire
Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
  • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
  • Gently lift up the keyboard starting at the top of the frame
  • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
  • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Ligne d'arrivée
3 autre(s) ont terminé cette réparation.
Marie K Bordley
Membre depuis le 30/09/2014
207 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-1, Buehl Fall 2014 Membre de l'équipe Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 membres
2 tutoriels rédigés
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 51
Total : 2,569
