Aller au contenu principal
Dell Inspiron Mini 1012 Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: étape 1, image 1 de 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: étape 1, image 2 de 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: étape 1, image 3 de 3
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: étape 2, image 1 de 3 Dell Inspiron Mini 1012 Screen Replacement: étape 2, image 2 de 3 Dell Inspiron Mini 1012 Screen Replacement: étape 2, image 3 de 3
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: étape 3, image 1 de 3 Dell Inspiron Mini 1012 Screen Replacement: étape 3, image 2 de 3 Dell Inspiron Mini 1012 Screen Replacement: étape 3, image 3 de 3
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: étape 4, image 1 de 3 Dell Inspiron Mini 1012 Screen Replacement: étape 4, image 2 de 3 Dell Inspiron Mini 1012 Screen Replacement: étape 4, image 3 de 3
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
To reassemble your device, follow guide instructions.
2 autres ont terminé cette réparation.
sabinabarajas
Membre depuis le 10/17/15
372 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 2-2, Kuhn Fall 2015 Membre de l'équipe Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 membre
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 1,310
