Aller au contenu principal
Dell Inspiron N4010 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron N4010 Display Assembly Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron N4010 Display Assembly Replacement, Open the Display: étape 2, image 1 de 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron N4010 Display Assembly Replacement, Disconnecting the Display Cable: étape 3, image 1 de 1
    • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
  4. Dell Inspiron N4010 Display Assembly Replacement, Remove the Cables: étape 4, image 1 de 1
    • Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
  5. Dell Inspiron N4010 Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
    • Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
  6. Dell Inspiron N4010 Display Assembly Replacement, Remove the Display Assembly: étape 6, image 1 de 1
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron N4010 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 2 Dell Inspiron N4010 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 2 de 2
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron N4010 Display Assembly Replacement, Routing the Cables: étape 8, image 1 de 1
    • Route the Mini-Card antenna cables and display cable through the routing guides.
  9. Dell Inspiron N4010 Display Assembly Replacement, Connect the Display Cable: étape 9, image 1 de 1
    • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
  10. Dell Inspiron N4010 Display Assembly Replacement, Close the Display: étape 10, image 1 de 1
    • Close the display and turn the computer over.
  11. Dell Inspiron N4010 Display Assembly Replacement, Replace the Screws: étape 11, image 1 de 1
    • Replace the two screws that secure the display assembly to the computer base.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 10
Total : 576
