Aller au contenu principal
Dell Inspiron N4010 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 2, image 1 de 1
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 5, image 1 de 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron N4010 Hard Drive Replacement, Align the Screw Holes: étape 6, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 7, image 1 de 1
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron N4010 Hard Drive Replacement, Replace the Screws: étape 8, image 1 de 1
    • Replace the two screws that secure the hard-drive assembly to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 14
Total : 783
