Aller au contenu principal
Dell Inspiron N4010 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron N4010 Keyboard Replacement: étape 2, image 2 de 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: étape 3, image 1 de 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: étape 5, image 1 de 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: étape 7, image 1 de 2 Dell Inspiron N4010 Keyboard Replacement: étape 7, image 2 de 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: étape 8, image 1 de 2 Dell Inspiron N4010 Keyboard Replacement: étape 8, image 2 de 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: étape 9, image 1 de 2 Dell Inspiron N4010 Keyboard Replacement: étape 9, image 2 de 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
2 autres ont terminé cette réparation.
Jonathan Sellier
Membre depuis le 09/26/17
952 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S13-G5, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 membres
9 tutoriels rédigés
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 14
Total : 988
