Introduction
Does your hard drive appear to be failing or need a replacement? This guide will help you replace the hard drive in several simple steps.
Ce dont vous avez besoin
Locate the battery on the underside of the laptop.
Push the two battery clips following the direction of the arrows.
Unscrew the six 2.5x5mm screws from the motherboard.
Note that this screw may be "retained" by the loop at the end of the grounding wire.
14 autres ont terminé cette réparation.
5 commentaires
Hello. I believe that between step 3 and 4 You should add another step - “Remove the two 2x3 mm screws in the laptop battery compartment (below the battery)“.
I second this! Critical omission! Good catch!
Wils -
Separating the motherboard from the daughterboard in step 20 is quite challenging.
Probably THE worst design ever! Thank you Dell for allowing easy access to the RAM sticks, but burying the most volatile and data-critical part of the laptop.
Thank u for guide for opening procedure
