Aller au contenu principal
Dell Inspiron N4110 Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron N4110 Screen Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: étape 2, image 1 de 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: étape 3, image 1 de 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: étape 4, image 1 de 3 Dell Inspiron N4110 Screen Replacement, Screen: étape 4, image 2 de 3 Dell Inspiron N4110 Screen Replacement, Screen: étape 4, image 3 de 3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: étape 5, image 1 de 2 Dell Inspiron N4110 Screen Replacement: étape 5, image 2 de 2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: étape 6, image 1 de 2 Dell Inspiron N4110 Screen Replacement: étape 6, image 2 de 2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: étape 7, image 1 de 3 Dell Inspiron N4110 Screen Replacement: étape 7, image 2 de 3 Dell Inspiron N4110 Screen Replacement: étape 7, image 3 de 3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: étape 8, image 1 de 2 Dell Inspiron N4110 Screen Replacement: étape 8, image 2 de 2
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: étape 9, image 1 de 3 Dell Inspiron N4110 Screen Replacement: étape 9, image 2 de 3 Dell Inspiron N4110 Screen Replacement: étape 9, image 3 de 3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: étape 10, image 1 de 1
    • The screen can now be fully removed from the computer.
Abigail Keith
Membre depuis le 03/20/18
505 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 1,210
