Aller au contenu principal
Dell Inspiron N5010 Hard Drive Replacement
Ce dont vous avez besoin
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron N5010 Hard Drive Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the four screws that secure the hard-drive assembly.
  2. Dell Inspiron N5010 Hard Drive Replacement, Lifting the Hard Drive Assembly: étape 3, image 1 de 1
    • Turn the computer over and lift the hard-drive assembly out of the hard-drive bay to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron N5010 Hard Drive Replacement, Disconnect the Interposer: étape 4, image 1 de 1
    • Pull the interposer to disconnect it from the hard drive.
  4. Dell Inspiron N5010 Hard Drive Replacement, Connect the Interposer: étape 5, image 1 de 1
    • Connect the interposer to the NEW hard drive.
  5. Dell Inspiron N5010 Hard Drive Replacement, Align the Hard Drive Assembly: étape 6, image 1 de 1
    • Align the hard-drive assembly with the connector on the system board and press the hard-drive assembly into the hard-drive bay until it is fully seated.
  6. Dell Inspiron N5010 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Turn the computer over and replace the four screws that secure the hard-drive assembly.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 18
Total : 2,090
