Aller au contenu principal
Dell Inspiron N5010 Memory Modules Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: étape 2, image 1 de 2 Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: étape 2, image 2 de 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron N5010 Memory Modules Replacement, Remove the Memory Module: étape 3, image 1 de 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: étape 4, image 1 de 2 Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: étape 4, image 2 de 2
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron N5010 Memory Modules Replacement, Install the Memory Module: étape 5, image 1 de 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 091 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
Un commentaire
I have dell Inspiron n5010 laptop with 2gb ram(2gb 1R*8 PC3-10600s-09-11-B2).I need to upgrade ram to 8gb.suggest me exact ram which supports my laptop.if you suggest the buying link,it would be more helpful to me.
Babu j Ramaswamy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 633
