Aller au contenu principal
Dell Inspiron N5030 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron N5030 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron N5030 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron N5030 Keyboard Replacement: étape 2, image 2 de 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Keyboard Replacement: étape 4, image 1 de 1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Keyboard Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Keyboard Replacement: étape 6, image 1 de 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Keyboard Replacement: étape 7, image 1 de 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Keyboard Replacement: étape 8, image 1 de 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Keyboard Replacement: étape 9, image 1 de 1
    • Remove the top keyboard panel.
5 autres ont terminé cette réparation.
Gunnar Salazar
Membre depuis le 09/30/13
128 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-59, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 membres
5 tutoriels rédigés
2 commentaires
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - Réponse
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 2,851
