Aller au contenu principal
Dell Inspiron N5050 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron N5050 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 Hard Drive Replacement: étape 3, image 1 de 2 Dell Inspiron N5050 Hard Drive Replacement: étape 3, image 2 de 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 Hard Drive Replacement: étape 5, image 1 de 2 Dell Inspiron N5050 Hard Drive Replacement: étape 5, image 2 de 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 Hard Drive Replacement: étape 6, image 1 de 3 Dell Inspiron N5050 Hard Drive Replacement: étape 6, image 2 de 3 Dell Inspiron N5050 Hard Drive Replacement: étape 6, image 3 de 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 Hard Drive Replacement: étape 7, image 1 de 3 Dell Inspiron N5050 Hard Drive Replacement: étape 7, image 2 de 3 Dell Inspiron N5050 Hard Drive Replacement: étape 7, image 3 de 3
    • Unscrew the two palmrest screws.
    • Lift the two, blue palmrest cables up and out of their sockets.
  8. Dell Inspiron N5050 Hard Drive Replacement: étape 8, image 1 de 2 Dell Inspiron N5050 Hard Drive Replacement: étape 8, image 2 de 2
    • Lift the entire surface (palmrest casing) to expose the motherboard underneath.
  9. Dell Inspiron N5050 Hard Drive Replacement: étape 9, image 1 de 1
    • Slide the hard drive right and up to remove it from the laptop.
11 autres ont terminé cette réparation.
Kristy Mayo
Membre depuis le 09/15/16
1 508 Réputation
3 tutoriels rédigés
Équipe
4 commentaires
Thanks again. This guide was made straightforward and clear.
jason acn - Réponse
Thanks you - The clear instructions make this guide easy to follow.
Jay - Réponse
wouldnt turn on after i re-assembled it
Taemon Coolz - Réponse
Sehr gute Arbeit
pouchman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 38
Total : 7,067
