Aller au contenu principal
Dell Inspiron i3558-5500BLK Memory Replacement
Ce dont vous avez besoin
  1. Dell Inspiron i3558-5500BLK Memory Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron i3558-5500BLK Memory Replacement, Keyboard: étape 1, image 2 de 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Memory Replacement: étape 2, image 1 de 3 Dell Inspiron i3558-5500BLK Memory Replacement: étape 2, image 2 de 3 Dell Inspiron i3558-5500BLK Memory Replacement: étape 2, image 3 de 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Memory Replacement, Battery: étape 3, image 1 de 3 Dell Inspiron i3558-5500BLK Memory Replacement, Battery: étape 3, image 2 de 3 Dell Inspiron i3558-5500BLK Memory Replacement, Battery: étape 3, image 3 de 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Memory Replacement, Back Cover: étape 4, image 1 de 2 Dell Inspiron i3558-5500BLK Memory Replacement, Back Cover: étape 4, image 2 de 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Memory Replacement: étape 5, image 1 de 2 Dell Inspiron i3558-5500BLK Memory Replacement: étape 5, image 2 de 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Memory Replacement: étape 6, image 1 de 3 Dell Inspiron i3558-5500BLK Memory Replacement: étape 6, image 2 de 3 Dell Inspiron i3558-5500BLK Memory Replacement: étape 6, image 3 de 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Memory Replacement: étape 7, image 1 de 2 Dell Inspiron i3558-5500BLK Memory Replacement: étape 7, image 2 de 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Memory Replacement, Memory / RAM: étape 8, image 1 de 3 Dell Inspiron i3558-5500BLK Memory Replacement, Memory / RAM: étape 8, image 2 de 3 Dell Inspiron i3558-5500BLK Memory Replacement, Memory / RAM: étape 8, image 3 de 3
    • Identify the RAM as shown in the image.
    • Gently press outward on the plastic guards to release the component.
  9. Dell Inspiron i3558-5500BLK Memory Replacement: étape 9, image 1 de 1
    • Lift the RAM out of the memory port by first pulling forward, away from the port, and then upward.
Nathan Ybanez
Membre depuis le 09/27/17
622 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S9-G5, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S9-G5, Banghart Fall 2017
CPSU-BANGHART-F17S9G5
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 7
Total : 766
