Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
  1. Flip your laptop over to view the bottom and locate the two locks.
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Slide the two locks away from each other.
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Pull battery out of the laptop. Your laptop's battery should be completely removed.
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Flip the laptop right side up.  Open the laptop. Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Gently flip the data cable latch away from the data cable with flat side of spudger. Lift the cable up and out. When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area.  When these are in place the cable is properly inserted.
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
  6. Close the lid, flip the laptop bottom side up with the battery at the top.
    • Close the lid, flip the laptop bottom side up with the battery at the top.
    • Remove the 11 screws holding the upper case to the lower case.
  7. Flip the laptop over and open the lid.
    • Flip the laptop over and open the lid.
    • Remove the two screws from the upper case.
  8. Gently unplug the power cable. You lift up on the dark gray latch. Pull the blue ribbon up.
    • Gently unplug the power cable.
    • You lift up on the dark gray latch.
    • Pull the blue ribbon up.
    • Gently unplug the touchpad cable.
    • Lift up on the dark gray latch.
  9. Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
    • Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
    • Work your way around the perimeter of the upper case.
10 autre(s) ont terminé cette réparation.
Tyler
Membre depuis le 19/06/2012
4 662 Réputation
16 tutoriels rédigés
Équipe
TechForce Membre de l'équipe TechForce
Business
2 membres
18 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 8
Total : 2,825
