Aller au contenu principal
Dell Latitude 3189 Power Jack Replacement
Ce dont vous avez besoin
  1. Dell Latitude 3189 Power Jack Replacement, Lower Case: étape 1, image 1 de 2 Dell Latitude 3189 Power Jack Replacement, Lower Case: étape 1, image 2 de 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Power Jack Replacement: étape 2, image 1 de 3 Dell Latitude 3189 Power Jack Replacement: étape 2, image 2 de 3 Dell Latitude 3189 Power Jack Replacement: étape 2, image 3 de 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Power Jack Replacement: étape 3, image 1 de 2 Dell Latitude 3189 Power Jack Replacement: étape 3, image 2 de 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Power Jack Replacement: étape 4, image 1 de 3 Dell Latitude 3189 Power Jack Replacement: étape 4, image 2 de 3 Dell Latitude 3189 Power Jack Replacement: étape 4, image 3 de 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Power Jack Replacement, Power Jack: étape 5, image 1 de 1
    • Use a spudger to push the charging port connector directly out of its motherboard port.
    • The charging port is located in the top-right corner of the device, near the hinge.
  6. Dell Latitude 3189 Power Jack Replacement: étape 6, image 1 de 2 Dell Latitude 3189 Power Jack Replacement: étape 6, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws that secure the power jack to the chassis.
  7. Dell Latitude 3189 Power Jack Replacement: étape 7, image 1 de 1
    • Slide and lift the power connector port away from the computer.
Bryan Pratt
Membre depuis le 02/14/24
601 Réputation
6 tutoriels rédigés
Équipe
University of Memphis, Team 2-3, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 2-3, Sneed Spring 2024
UM-SNEED-S24S2G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 45
