Aller au contenu principal
Dell Latitude 3190 Battery Replacement
Ce dont vous avez besoin
  1. Dell Latitude 3190 Battery Replacement, Base Cover: étape 1, image 1 de 2 Dell Latitude 3190 Battery Replacement, Base Cover: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Battery Replacement: étape 2, image 1 de 3 Dell Latitude 3190 Battery Replacement: étape 2, image 2 de 3 Dell Latitude 3190 Battery Replacement: étape 2, image 3 de 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Battery Replacement, Battery: étape 3, image 1 de 1
    • Locate the battery.
  4. Dell Latitude 3190 Battery Replacement: étape 4, image 1 de 3 Dell Latitude 3190 Battery Replacement: étape 4, image 2 de 3 Dell Latitude 3190 Battery Replacement: étape 4, image 3 de 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Battery Replacement: étape 5, image 1 de 3 Dell Latitude 3190 Battery Replacement: étape 5, image 2 de 3 Dell Latitude 3190 Battery Replacement: étape 5, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Battery Replacement: étape 6, image 1 de 3 Dell Latitude 3190 Battery Replacement: étape 6, image 2 de 3 Dell Latitude 3190 Battery Replacement: étape 6, image 3 de 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
Daniel Tzunum
Membre depuis le 09/01/21
235 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-5, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 51
Total : 2,598
