Aller au contenu principal
Dell Latitude 3190 Power Switch Board Replacement
Ce dont vous avez besoin
  1. Dell Latitude 3190 Power Switch Board Replacement, Base Cover: étape 1, image 1 de 2 Dell Latitude 3190 Power Switch Board Replacement, Base Cover: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Power Switch Board Replacement: étape 2, image 1 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 2, image 2 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 2, image 3 de 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Power Switch Board Replacement, Battery: étape 3, image 1 de 1
    • Locate the battery.
  4. Dell Latitude 3190 Power Switch Board Replacement: étape 4, image 1 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 4, image 2 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 4, image 3 de 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Power Switch Board Replacement: étape 5, image 1 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 5, image 2 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 5, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Power Switch Board Replacement: étape 6, image 1 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 6, image 2 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 6, image 3 de 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: étape 7, image 1 de 2 Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: étape 7, image 2 de 2
    • Disconnect the power switch cable from the motherboard.
  8. Dell Latitude 3190 Power Switch Board Replacement: étape 8, image 1 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 8, image 2 de 3 Dell Latitude 3190 Power Switch Board Replacement: étape 8, image 3 de 3
    • Remove the two 3 mm screws that secure the power switch board on the computer.
  9. Dell Latitude 3190 Power Switch Board Replacement: étape 9, image 1 de 2 Dell Latitude 3190 Power Switch Board Replacement: étape 9, image 2 de 2
    • Lift the power switchboard away from the computer.
Haley Smith
Membre depuis le 09/01/21
305 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-5, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 27
Total : 366
