Aller au contenu principal
Dell Latitude 3500 VGA Board Replacement
Ce dont vous avez besoin
  1. Dell Latitude 3500 VGA Board Replacement, Remove screws: étape 1, image 1 de 1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 VGA Board Replacement, Separate bottom cover and palmrest: étape 2, image 1 de 1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 VGA Board Replacement, Disconnect and Remove Battery: étape 3, image 1 de 1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 VGA Board Replacement, Disconnect Surrounding Connections from System Fan: étape 4, image 1 de 1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 VGA Board Replacement, Remove Fan Screws: étape 5, image 1 de 1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 VGA Board Replacement, Disconnect VGA Board: étape 6, image 1 de 1
    • Pull straight up from the motherboard
  7. Dell Latitude 3500 VGA Board Replacement, Remove Screws: étape 7, image 1 de 1
    • 2 screws
    • Board can now be safely removed from device
Jake
Membre depuis le 03/08/23
1 327 Réputation
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 36
