Aller au contenu principal
Dell Latitude 3520 System Fan Replacement
Ce dont vous avez besoin
  1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: étape 1, image 1 de 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 System Fan Replacement, Bottom Case: étape 2, image 1 de 3 Dell Latitude 3520 System Fan Replacement, Bottom Case: étape 2, image 2 de 3 Dell Latitude 3520 System Fan Replacement, Bottom Case: étape 2, image 3 de 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 System Fan Replacement, Battery: étape 3, image 1 de 1
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 System Fan Replacement: étape 4, image 1 de 2 Dell Latitude 3520 System Fan Replacement: étape 4, image 2 de 2
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 System Fan Replacement: étape 5, image 1 de 1
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 System Fan Replacement: étape 6, image 1 de 2 Dell Latitude 3520 System Fan Replacement: étape 6, image 2 de 2
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 System Fan Replacement: étape 7, image 1 de 1
    • Lift and remove the battery.
  8. Dell Latitude 3520 System Fan Replacement, System Fan: étape 8, image 1 de 1
    • Disconnect the system fan cable from the connector on the system board.
  9. Dell Latitude 3520 System Fan Replacement: étape 9, image 1 de 1
    • Remove the two 2mm Phillips #0 screws that secure the system fan.
  10. Dell Latitude 3520 System Fan Replacement: étape 10, image 1 de 1
    • Lift and remove the system fan.
Shawn Smith
Membre depuis le 09/08/23
871 Réputation
7 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 117
