Introduction
This guide will demonstrate the process of replacing RAM on a Dell Latitude 5401 series laptop.
Excessive use, poor ventilation, external or internal damage, and power surges may all result in RAM becoming dysfunctional and rendering the laptop useless. By following along, you will learn how to restore your laptop to working condition - allowing you to continue using it and helping to save both money and the environment!
Before you begin the repair, power off your device and disconnect it from the charger.
Ce dont vous avez besoin
Disconnect any devices plugged into the computer.
Hold the power button down for 5-10 seconds to shutdown the laptop.
Expose the seam that connects the laptop case by pulling on a corner screw while holding the base.
Insert a plastic card into the gap.
Slide the card around the perimeter of the case to release the clips.
Gently pry the laptop apart.
Congratulations, you have successfully replaced your laptop RAM, saved money, and reduced your carbon footprint!
