Aller au contenu principal
Dell Latitude 5480 Display Replacement
Ce dont vous avez besoin
  1. Dell Latitude 5480 Display Replacement, Lower Case: étape 1, image 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: étape 2, image 1 de 3 Dell Latitude 5480 Display Replacement: étape 2, image 2 de 3 Dell Latitude 5480 Display Replacement: étape 2, image 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: étape 3, image 1 de 2 Dell Latitude 5480 Display Replacement, Battery: étape 3, image 2 de 2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: étape 4, image 1 de 3 Dell Latitude 5480 Display Replacement: étape 4, image 2 de 3 Dell Latitude 5480 Display Replacement: étape 4, image 3 de 3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: étape 5, image 1 de 3 Dell Latitude 5480 Display Replacement, Display: étape 5, image 2 de 3 Dell Latitude 5480 Display Replacement, Display: étape 5, image 3 de 3
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: étape 6, image 1 de 3 Dell Latitude 5480 Display Replacement: étape 6, image 2 de 3 Dell Latitude 5480 Display Replacement: étape 6, image 3 de 3
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: étape 7, image 1 de 3 Dell Latitude 5480 Display Replacement: étape 7, image 2 de 3 Dell Latitude 5480 Display Replacement: étape 7, image 3 de 3
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
Valencia Vidrine
Membre depuis le 02/16/24
457 Réputation
5 tutoriels rédigés
Équipe
University of Memphis, Team 2-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 2-2, Sneed Spring 2024
UM-SNEED-S24S2G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 29
Total : 53
