Aller au contenu principal
Dell Latitude 5480 Power Jack Replacement
Ce dont vous avez besoin
  1. Dell Latitude 5480 Power Jack Replacement, Lower Case: étape 1, image 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Power Jack Replacement: étape 2, image 1 de 3 Dell Latitude 5480 Power Jack Replacement: étape 2, image 2 de 3 Dell Latitude 5480 Power Jack Replacement: étape 2, image 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: étape 3, image 1 de 2 Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: étape 3, image 2 de 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Power Jack Replacement, Power Jack: étape 4, image 1 de 3 Dell Latitude 5480 Power Jack Replacement, Power Jack: étape 4, image 2 de 3 Dell Latitude 5480 Power Jack Replacement, Power Jack: étape 4, image 3 de 3
    • Unscrew the right 3.7 mm screw that secures the fabric flap and the right side of the charging port bracket.
    • Carefully lift the flap out of the way of the left charging port bracket screw.
    • Unscrew the second 3.7 mm screw on the left side of the charging port bracket.
  5. Dell Latitude 5480 Power Jack Replacement: étape 5, image 1 de 3 Dell Latitude 5480 Power Jack Replacement: étape 5, image 2 de 3 Dell Latitude 5480 Power Jack Replacement: étape 5, image 3 de 3
    • Remove the metal bracket that secures the charging port.
    • Keep the fabric flap tucked out of the way.
    • Use the pointed edge of a spudger to push the charging port motherboard connector directly out of its port.
  6. Dell Latitude 5480 Power Jack Replacement: étape 6, image 1 de 1
    • Lift the entire charging port assembly up and out of the chassis.
Valencia Vidrine
Membre depuis le 02/16/24
457 Réputation
5 tutoriels rédigés
Équipe
University of Memphis, Team 2-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 2-2, Sneed Spring 2024
UM-SNEED-S24S2G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 18
Total : 58
