Aller au contenu principal
Dell Latitude 5480 Speakers Replacement
Ce dont vous avez besoin
  1. Dell Latitude 5480 Speakers Replacement, Lower Case: étape 1, image 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Speakers Replacement: étape 2, image 1 de 3 Dell Latitude 5480 Speakers Replacement: étape 2, image 2 de 3 Dell Latitude 5480 Speakers Replacement: étape 2, image 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Speakers Replacement, Battery: étape 3, image 1 de 2 Dell Latitude 5480 Speakers Replacement, Battery: étape 3, image 2 de 2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Speakers Replacement: étape 4, image 1 de 3 Dell Latitude 5480 Speakers Replacement: étape 4, image 2 de 3 Dell Latitude 5480 Speakers Replacement: étape 4, image 3 de 3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: étape 5, image 1 de 2 Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: étape 5, image 2 de 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  6. Dell Latitude 5480 Speakers Replacement, Speakers: étape 6, image 1 de 3 Dell Latitude 5480 Speakers Replacement, Speakers: étape 6, image 2 de 3 Dell Latitude 5480 Speakers Replacement, Speakers: étape 6, image 3 de 3
    • Flip the motherboard to view the speaker cable connection on the underside.
    • Flip up the speaker cable ZIF locking flap.
    • Disconnect the touchpad ribbon cable.
  7. Dell Latitude 5480 Speakers Replacement: étape 7, image 1 de 3 Dell Latitude 5480 Speakers Replacement: étape 7, image 2 de 3 Dell Latitude 5480 Speakers Replacement: étape 7, image 3 de 3
    • Disconnect the speaker cable by pulling it directly out of its motherboard port.
    • Do not pull on the wires.
  8. Dell Latitude 5480 Speakers Replacement: étape 8, image 1 de 3 Dell Latitude 5480 Speakers Replacement: étape 8, image 2 de 3 Dell Latitude 5480 Speakers Replacement: étape 8, image 3 de 3
    • Carefully unseat the wire between the two speakers from the clips.
    • Lift the speakers up and out of the chassis.
Karston Salsbury
Membre depuis le 02/16/24
243 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 2-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 2-2, Sneed Spring 2024
UM-SNEED-S24S2G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 20
Total : 57
