Introduction
If you need to repair or replace the fan component in the Dell Latitude 7390, this guide shows you step-by-step how to access it.
Prior to starting this repair, be sure to turn off your laptop and unplug from the power adapter.
Ce dont vous avez besoin
Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
4 autres ont terminé cette réparation.
Un commentaire
Wonderful!! :)
Since a couple of weeks, my laptop is heating up to 95 degrees even when noting much is going on. I wanted to have it fixed, but I don't have hundreds of dollars to spend to fix a laptop that (in apparence) works just fine. But I know it's not smart, and it keeps stressing me out.
With the step-by-step explanations and photos, it doesn't look hard at all to do it by myself... and the replacement part is like<30-50$ on Dell's website! Hallelujia!!
Thanks a lot!!
*The only thing that would be nice to add is the model name/number of the heatsink or fan that I need to use to make the replacement (the heatsink isn't mentioned in the parts that you need).
