Aller au contenu principal
Dell Latitude 7420 Display Replacement
Ce dont vous avez besoin
  1. Dell Latitude 7420 Display Replacement, Back Case: étape 1, image 1 de 3 Dell Latitude 7420 Display Replacement, Back Case: étape 1, image 2 de 3 Dell Latitude 7420 Display Replacement, Back Case: étape 1, image 3 de 3
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Display Replacement, Display: étape 2, image 1 de 3 Dell Latitude 7420 Display Replacement, Display: étape 2, image 2 de 3 Dell Latitude 7420 Display Replacement, Display: étape 2, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the three, 2 mm screws fastening the cable covers.
    • Remove both cable covers.
  3. Dell Latitude 7420 Display Replacement: étape 3, image 1 de 2 Dell Latitude 7420 Display Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to detach the coaxial cables from the Wi-Fi card.
    • Disconnect the remaining cables connecting the display assembly to the board.
  4. Dell Latitude 7420 Display Replacement: étape 4, image 1 de 3 Dell Latitude 7420 Display Replacement: étape 4, image 2 de 3 Dell Latitude 7420 Display Replacement: étape 4, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws securing the display hinges.
    • There are two screws to remove from each hinge.
    • Lift the base to pull the display assembly free.
  5. Dell Latitude 7420 Display Replacement: étape 5, image 1 de 1
    • Separate the display assembly from the base of the laptop.
nuredinroba
Membre depuis le 02/02/23
209 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-2, Pee Spring 2023 Membre de l'équipe Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 35
30 derniers jours : 81
Total : 1,817
