Aller au contenu principal
Dell Latitude D600 RAM (Main Memory) Replacement
Ce dont vous avez besoin
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: étape 1, image 1 de 1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: étape 2, image 1 de 2 Dell Latitude D600 RAM (Main Memory) Replacement: étape 2, image 2 de 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: étape 3, image 1 de 1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): étape 4, image 1 de 2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): étape 4, image 2 de 2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: étape 5, image 1 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: étape 5, image 2 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: étape 5, image 3 de 3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: étape 6, image 1 de 1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: étape 7, image 1 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: étape 7, image 2 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: étape 7, image 3 de 3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: étape 8, image 1 de 1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
6 autres ont terminé cette réparation.
Joseph
Membre depuis le 07/16/14
1 497 Réputation
5 tutoriels rédigés
Un commentaire
Almost perfect: easy; clear;
Herman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 2,918
