Aller au contenu principal
Dell Latitude D610 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude D610 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Latitude D610 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Keyboard Replacement: étape 2, image 1 de 3 Dell Latitude D610 Keyboard Replacement: étape 2, image 2 de 3 Dell Latitude D610 Keyboard Replacement: étape 2, image 3 de 3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Keyboard Replacement: étape 3, image 1 de 1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Dell Latitude D610 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Dell Latitude D610 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Keyboard Replacement: étape 5, image 1 de 2 Dell Latitude D610 Keyboard Replacement: étape 5, image 2 de 2
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Keyboard Replacement: étape 6, image 1 de 2 Dell Latitude D610 Keyboard Replacement: étape 6, image 2 de 2
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Keyboard Replacement: étape 7, image 1 de 3 Dell Latitude D610 Keyboard Replacement: étape 7, image 2 de 3 Dell Latitude D610 Keyboard Replacement: étape 7, image 3 de 3
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
4 autres ont terminé cette réparation.
Jordan Barham
Membre depuis le 01/26/14
459 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-24, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 2,003
