Aller au contenu principal
Dell Latitude D620 CD Drive Replacement
Ce dont vous avez besoin
  1. Dell Latitude D620 CD Drive Replacement, Keyboard: étape 1, image 1 de 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 CD Drive Replacement: étape 2, image 1 de 3 Dell Latitude D620 CD Drive Replacement: étape 2, image 2 de 3 Dell Latitude D620 CD Drive Replacement: étape 2, image 3 de 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 CD Drive Replacement: étape 3, image 1 de 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 CD Drive Replacement: étape 4, image 1 de 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 CD Drive Replacement: étape 5, image 1 de 2 Dell Latitude D620 CD Drive Replacement: étape 5, image 2 de 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 CD Drive Replacement: étape 6, image 1 de 2 Dell Latitude D620 CD Drive Replacement: étape 6, image 2 de 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 CD Drive Replacement: étape 7, image 1 de 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 CD Drive Replacement, CD Drive: étape 8, image 1 de 2 Dell Latitude D620 CD Drive Replacement, CD Drive: étape 8, image 2 de 2
    • Press in the tab on the bottom right side of the CD drive
    • The tab comes out on its own; there is no need to pull it out manually.
  9. Dell Latitude D620 CD Drive Replacement: étape 9, image 1 de 1
    • Gently pull the tab to remove the disk tray.
10 autres ont terminé cette réparation.
Ivan
Membre depuis le 04/15/10
194 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-35, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 8,372
