Aller au contenu principal
Dell Latitude D620 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude D620 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 Keyboard Replacement: étape 2, image 1 de 3 Dell Latitude D620 Keyboard Replacement: étape 2, image 2 de 3 Dell Latitude D620 Keyboard Replacement: étape 2, image 3 de 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Keyboard Replacement: étape 3, image 1 de 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Keyboard Replacement: étape 4, image 1 de 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Keyboard Replacement: étape 5, image 1 de 2 Dell Latitude D620 Keyboard Replacement: étape 5, image 2 de 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Keyboard Replacement: étape 6, image 1 de 2 Dell Latitude D620 Keyboard Replacement: étape 6, image 2 de 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Keyboard Replacement: étape 7, image 1 de 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
10 autres ont terminé cette réparation.
Miguel Wong
Membre depuis le 04/15/10
562 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-35, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 membres
4 tutoriels rédigés
Un commentaire
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 16,772
