Aller au contenu principal
Dell Latitude D620 RAM Replacement
Ce dont vous avez besoin
  1. Dell Latitude D620 RAM Replacement, Keyboard: étape 1, image 1 de 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 RAM Replacement: étape 2, image 1 de 3 Dell Latitude D620 RAM Replacement: étape 2, image 2 de 3 Dell Latitude D620 RAM Replacement: étape 2, image 3 de 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 RAM Replacement: étape 3, image 1 de 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 RAM Replacement: étape 4, image 1 de 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 RAM Replacement: étape 5, image 1 de 2 Dell Latitude D620 RAM Replacement: étape 5, image 2 de 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 RAM Replacement: étape 6, image 1 de 2 Dell Latitude D620 RAM Replacement: étape 6, image 2 de 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 RAM Replacement: étape 7, image 1 de 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 RAM Replacement, RAM: étape 8, image 1 de 2 Dell Latitude D620 RAM Replacement, RAM: étape 8, image 2 de 2
    • With the keyboard removed, you should be able to see ram slot A.
    • Place new ram into the slot making sure it is aligned
  9. Dell Latitude D620 RAM Replacement: étape 9, image 1 de 1
    • Replace the keyboard by following the previous steps in reverse
    • Close the laptop, and flip it over onto its backside
  10. Dell Latitude D620 RAM Replacement: étape 10, image 1 de 2 Dell Latitude D620 RAM Replacement: étape 10, image 2 de 2
    • Loosen the screw that holds the RAM cover in place.
    • The screw cannot be fully removed since it is attached to the RAM cover.
  11. Dell Latitude D620 RAM Replacement: étape 11, image 1 de 2 Dell Latitude D620 RAM Replacement: étape 11, image 2 de 2
    • Insert new ram into slot B
25 autres ont terminé cette réparation.
Miguel Wong
Membre depuis le 04/15/10
556 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-35, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 membres
4 tutoriels rédigés
2 commentaires
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
Michael Erwin - Réponse
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
ppgauchard -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 17
Total : 34,255
