Introduction
Introduction
The wireless card is what allows us to connect to with out the use of a ether cable. This is a very important component and must be replace if damaged.
This Guide Will Teach You
- The basic safety steps to follow when fixing the laptop
- To disassemble of the laptops internals and reach the Wireless card
- Precautions to prevent further damage to the laptop
- Tools needed for the repair
Ce dont vous avez besoin
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
Turn the laptop over so its bottom is facing you.
With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
To reassemble your device, follow these instructions in reverse order with your new wireless card.
5 autres ont terminé cette réparation.
2 commentaires
1) You don't have to disconnect the keyboard cable to replace the WiFi card.
2) You may have three wires connected to the wifi card, disconnect all three
3) If your new wifi card has three sockets the grey lead heading off towards the front of the machine is for the middle socket; it has a plastic wrapper that can be slid off.
What type of Wi-Fi card is needed to be ordered to make it dual-band AC compatible?
