Aller au contenu principal
Dell Latitude D820 Screen Replacement
Ce dont vous avez besoin
  1. Dell Latitude D820 Screen Replacement, Battery: étape 1, image 1 de 1
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Screen Replacement, Keyboard: étape 2, image 1 de 3 Dell Latitude D820 Screen Replacement, Keyboard: étape 2, image 2 de 3 Dell Latitude D820 Screen Replacement, Keyboard: étape 2, image 3 de 3
    • Open laptop lid and extend screen until it is parallel with the keyboard.
    • Locate the notch in the upper right corner of the keyboard (just above the 'page up' button).
    • Insert the plastic spudger and very gently lift the faceplate. It will make a soft snapping sound.
    • Set aside.
  3. Dell Latitude D820 Screen Replacement: étape 3, image 1 de 1
    • Locate the three philips head screws above the keyboard. One is above the 'Pause/Break' key; one above the F7 key and one above the 'Esc' key. Remove all three.
  4. Dell Latitude D820 Screen Replacement: étape 4, image 1 de 1
    • Gently lift top of keyboard and lay forward on palm rest.
    • Locate blue pull tab and gently disconnect ribbon cable from motherboard.
  5. Dell Latitude D820 Screen Replacement, Screen: étape 5, image 1 de 3 Dell Latitude D820 Screen Replacement, Screen: étape 5, image 2 de 3 Dell Latitude D820 Screen Replacement, Screen: étape 5, image 3 de 3
    • Locate and remove the rubber stoppers around the display to expose the screws; set aside.
    • Remove the screws located under the rubber stoppers that were removed. These measure 5.88mm in length and 2.40 mm in width
    • Then gently pull up and out on the display bezel (frame). It has plastic retaining clips all around it so you may want to use a plastic pry tool to assist at first. Try not to break them.
  6. Dell Latitude D820 Screen Replacement: étape 6, image 1 de 3 Dell Latitude D820 Screen Replacement: étape 6, image 2 de 3 Dell Latitude D820 Screen Replacement: étape 6, image 3 de 3
    • Locate the 8 numbered screws and remove in order. These philip head screws measure 5.70mm in length and 2.40mm in width
    • Gently lift screen being careful of the ribbon cables.
  7. Dell Latitude D820 Screen Replacement: étape 7, image 1 de 2 Dell Latitude D820 Screen Replacement: étape 7, image 2 de 2
    • The ribbon cable at the top of the screen uses a locking connector. Gently squeeze the levers on each side to release the lock and tug the ribbon cable down towards the bottom of the screen.
    • Set this connection aside.
  8. Dell Latitude D820 Screen Replacement: étape 8, image 1 de 3 Dell Latitude D820 Screen Replacement: étape 8, image 2 de 3 Dell Latitude D820 Screen Replacement: étape 8, image 3 de 3
    • There is a small ribbon cable attached at the bottom of the screen also. Gently pull up on the blue tag to disconnect.
    • At this point remove the old display and connect the new one paying close attention to your finger placement to ensure you do not touch where the stickers say "DO NOT TOUCH".
2 autres ont terminé cette réparation.
Henry
Membre depuis le 09/02/14
1 431 Réputation
4 tutoriels rédigés
Équipe
Pasco Hernando, Team 1-2, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 1-2, Prince Fall 2014
PHSC-PRINCE-F14S1G2
10 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 2,885
