Aller au contenu principal
Dell Latitude E4200 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: étape 1, image 1 de 1
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: étape 2, image 1 de 1
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: étape 3, image 1 de 1
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: étape 5, image 1 de 2 Dell Latitude E4200 Keyboard Replacement: étape 5, image 2 de 2
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: étape 6, image 1 de 1
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: étape 7, image 1 de 1
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: étape 8, image 1 de 1
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: étape 9, image 1 de 1
    • Completely lift the keyboard from the device, as they are now disassembled.
3 autres ont terminé cette réparation.
Michelina Carbone
Membre depuis le 03/22/15
197 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 5-6, Williams Spring 2015 Membre de l'équipe Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 16
30 derniers jours : 19
Total : 4,388
