Aller au contenu principal
Dell Latitude E4200 RAM Replacement
Ce dont vous avez besoin
  1. Dell Latitude E4200 RAM Replacement, Back Panel: étape 1, image 1 de 1
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 RAM Replacement: étape 2, image 1 de 3 Dell Latitude E4200 RAM Replacement: étape 2, image 2 de 3 Dell Latitude E4200 RAM Replacement: étape 2, image 3 de 3
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 RAM Replacement: étape 3, image 1 de 1
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 RAM Replacement, Remove the back panel: étape 4, image 1 de 1
    • Once you removed the back panel, the RAM will easily be located.
    • Be sure to remove the battery first
  5. Dell Latitude E4200 RAM Replacement, Take out the RAM: étape 5, image 1 de 2 Dell Latitude E4200 RAM Replacement, Take out the RAM: étape 5, image 2 de 2
    • Place your thumbs on each side of the RAM tabs.
    • Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
    • The RAM should "bump up" after you push away the tabs.
  6. Dell Latitude E4200 RAM Replacement: étape 6, image 1 de 3 Dell Latitude E4200 RAM Replacement: étape 6, image 2 de 3 Dell Latitude E4200 RAM Replacement: étape 6, image 3 de 3
    • Gently grab each side of the RAM and remove it from the device.
    • Please do not touch connection side of the RAM (shown in orange) with fingers. It might causes possible corrosion to the connection.
2 autres ont terminé cette réparation.
Chao Wei
Membre depuis le 03/22/15
146 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 5-6, Williams Spring 2015 Membre de l'équipe Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 24
Total : 2,765
