Introduction
This guide walks through how to remove and replace a display on the Dell Latitude E4310 laptop in the event of a broken or bad display.
Power down the laptop and remove all power cords.
  • Power down the laptop and remove all power cords.
Ajouter un commentaire
Push in the battery release button with your thumb.
  • Push in the battery release button with your thumb.
  • Pull up on the battery to remove.
  • Open up the laptop and flatten it down on a workable surface.
  • Turn it around so that the screen is closest to you.
  • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
  • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
  • Remove the bezel.
  • Remove the six 0.3mm Phillips #1 screws.
  • Remove the two 0.5mm Phillips #1 screws.
  • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  • Use a pair of tweezers to flip the blue tape 180 degrees.
  • By flipping the tape you disconnect the display connector.
  • Remove the screen from the laptop.
3 autre(s) ont terminé cette réparation.
Aylin
Membre depuis le 21/02/2018
226 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 85
